2001 volvo transmission problem
I had a guy replace the tranny fluid, now trannys shot, he put fluid from top. do i need a new tranny or can this be fixed another way? thanks:)
if repalce tranmission, will the car start and go, or do i need any code from dealer? i really need help thanks in advance guys, take care and best regards. |
The shop that did the work needs to step up. Probably small claims court for you. However, I did read here or another forum where another member did this and came up with a repair method. Something about capturing the plates or gears. Sorry, don't remember much, but know it is possible to do (and probably not easy). By now you know the only way to add oil is through the did stick.
Jerry |
