2002 V70 Brake Booster DIY
Old Jan 8, 2011 | 09:57 PM
VolvoT5er's Avatar
Default 2002 V70 Brake Booster DIY
I am facing a replacement of the booster on my wife's 2002 V70 t5. Read previous post on DIY - but not sure if that was for an older model 850. Anyone with experience on this model? Is it possible to do it without disconnecting brake lines. I really want to avoid a bleed. And are there any tips or tricks for this model year?
Thanks in advance
James
Old Jan 8, 2011 | 11:48 PM
gdog's Avatar
Ck the stickies at top of V70 section:
https://volvoforums.com/forum/volvo-v70-13/brake-booster-replacement-6989/
Old Jan 10, 2011 | 09:00 AM
VolvoT5er's Avatar
Default Booster DIY - Follow up
GDOG Thanks for the reference. I did read the tread. My one outstanding question that I can't seem to answer from the Booster DIY Sticky is...
if the v70 setup in the engine compartment is any different from say an older model 850. Mine is a 2002 T-5 and I really just want to make sure I don't have to disconnect lines with this model.
I haven't bled ABS brakes a lot and that may change my decision to swap out the booster or have someone else do it.
If you have any additional advice that would be great. Thanks
James
Old Jan 10, 2011 | 10:53 PM
gdog's Avatar
I don't have a V70 and never changed out the brake booster on any volvo so can't comment on that... Personally i don't like to bend brake lines if i don't have to...
But if you're going to bleed ABS brakes i would definitely recommend using a pressure bleeder like the one in this link:
http://www.amazon.com/Motive-Product.../dp/B0002KM5M4
These work really well to do your periodic 2-3 year brake fluid flush too, so it pays for itself pretty quickly...
bluew
Jul 12, 2013 03:50 PM
IMCHicago
Jun 15, 2011 05:43 PM
jeffmo
Apr 11, 2011 05:42 PM
snpklinefelter
Dec 22, 2009 06:26 AM
