-   Volvo V70 (https://volvoforums.com/forum/volvo-v70-13/)
-   -   2002 V70 T5 Clock Problem, Advances Continuously (https://volvoforums.com/forum/volvo-v70-13/2002-v70-t5-clock-problem-advances-continuously-42118/)
bingobangobongo Jun 1, 2010 04:16 PM
My 2002 V70 T5's clock in the instrument cluster will advance continuously as if a ghost is trying to set it at high speed. This is happening most times after start. If I start the car and it works normally and I try to set the clock I am able to sometimes, but other times it starts to race again. Also, while the clock is racing I am unable to stop it with the setting knob. The trip odometer will not respond to me trying to reset or change from 1 to 2 while the clock is racing.
Any guesses?
Thanks in advance.
kaneben Jun 8, 2011 12:14 AM
xc70 2003 Clock Problem - Advances Continuously
My clock in our 2003 xc70 has begun to do exactly the same thing as the previous poster. Did you find a solution?
kojot602 Sep 9, 2011 02:39 PM
V70 clock
My V70 has same problem 2 weeks ago. I don't know what is it. And the daily counter is reset sometimes. I think it's related with the clock problem :confused:
Any idea?
kaneben Apr 18, 2014 05:58 PM
DIM replaced - clock works!
I eventually had to replace a flaky Driver Information Module or Instrument Cluster - it started with the clock then intermittent instruments etc - sounds like the 2002 and 2003 models were susceptible. Sounds like the circuit boards would have issues (heat, solder, etc). A company in Canada called Xemodex can send a refurbished guaranteed for life module for under $500. Definitely better than the dealer's $1,400. I've read where others had success reflowing solder on the circuit boards but that was beyond my comfort for such small chips.
