ABS MODULE replacement V70 2001
Hi Guys, I have zero brake fluid to drivers side caliper (UK car) New Caliper fitted replacement flex hose, so Im assuming that the ABS Module is at fault? I have a used module for this model . In order to fit this I need to remove the FuseBox, any advice much appreciated. Im assuming that the 803 Radio does not require a code?
| All times are GMT -5. The time now is 12:56 AM. |
