Broken remote key kills the engine. (7-month old post)
Old Jul 23, 2010 | 12:14 PM
awindrider's Avatar
Default Broken remote key kills the engine. (7-month old post)
Hello,
I’m owner of a 2005 V70, the blade key spring stopped working so the key is loose and the remote has a key ring which I use to attach 5 regular keys to it.
The problem is that when the key is inserted in to the ignition, the remote and the keys are at the 90 deg. Angle to the ignition key and hanging downwards and pointing to the floor (in unbroken situation, the remote and the ignition key are in a straight line).
The 5 keys plus a key ring do not weight that much but bumps in the roads make the mass to move up and down and eventually slowly turns off the ignition.
It took me awhile to figure out that the keys weight eventually turned off the engine. It is scary situation when driving 65-70 m/h on the freeways and suddenly you have no steering power and no engine and the cars approaching you from all directions. Volvo USA and Volvo Santa Monica Volvo are ignorance and recommend either to remove the keys or pay $300 for the replacement for another same faulty design without taking any responsibilities.
I am posting this to see if others have had similar issues.
Allan
Old Jul 28, 2010 | 04:26 AM
jackdawson's Avatar
I haven't had such issue earlier,so wont be able to guide you.may be someone else can help you out.
Old Jul 28, 2010 | 09:45 AM
jks2's Avatar
Welcome to the forum. Never had the problem you mention.
jimmyodonnell
Sep 17, 2010 10:54 PM
bmangn
Sep 8, 2010 07:40 PM
eltroco
Sep 5, 2010 09:45 AM
awindrider
Jul 23, 2010 06:26 PM
