A/C help
I just got a new (new to me) 2000 V70 with 169,500 miles. The a/c is super cold sometimes, and then when I am in trafic or slow down the fan stays on but the temp of the air goes warm?? then if i turn it off and back on it seem to come back a live (nice and cold). however that only works a few times, then only warm (hot air in NC), until it sits for a few minutes (turned off). i checked the pressures and they seem pretty good. Any ideas or help would be awesome.
owner of 2 vovlos with a total of almost 400,000 miles
That's a classic symptom of what is described above. I've been installing reman compressors, driers and orifice tubes when this happens because the system is probably due for a service, anyway. It is hard to pull the clutch with the compressor installed and if you open the system, you might as well do the entire thing.
I had the exact same issue with my 01 V70 and was able to pull the clutch off the compressor and reshim it without taking the compressor out. I will say it is a pain in the butt and takes a bit of patience put totally pays off and saves ya from having to buy a new or reman compressor. I did mine last spring and it's still working perfectly with no issues.
markjenross
11-07-2007 08:02 PM
