-   Volvo V70 (https://volvoforums.com/forum/volvo-v70-13/)
-   -   Cabin Air filter? (https://volvoforums.com/forum/volvo-v70-13/cabin-air-filter-3087/)
mickemus66 Oct 14, 2005 12:54 AM
Cabin Air filter?
i have an V70 T5 2001, and wonder where is the cabin filter located and how hard is it to change it?
some people say its under the glove apartment, some inside the where the engine is, i dont know???
any tip would be helpful,
thanks.
reg Oct 14, 2005 03:28 PM
RE: Cabin Air filter?
On a c-70 it is under the cowl on the passenger side................... One has to remove appx 3 screws and lift up the plastic shroud and replace it. I would think that is where yours is.
tech Oct 14, 2005 10:05 PM
ORIGINAL: mickemus66
thanks.
Yours is under the dash on the passenger side.You have to remove the lower dash panel.Then look for a black cover with 4 torxes screws.Remove the cover and then the filter.
reg Oct 14, 2005 10:32 PM
not even close was I..............
R.
mickemus66 Oct 14, 2005 10:42 PM
thanks guys, will look in to it tonite.
mickemus
tech Oct 14, 2005 10:43 PM
The 2001 and newer are just like the S60 and S80.
The 2000 S/V/C 70's are like yours.The C70 is like that till 2004.
satchmodog Oct 14, 2005 11:54 PM
Just did mine tonight. Took all of ten minutes. Man was that sucker dirty.
reg Oct 15, 2005 11:32 AM
I believe that Tech will tell you that changing it will prolong the life of the evaporator in your AC system...............inexpensive maintenance!
R.
tech Oct 15, 2005 11:51 AM
ORIGINAL: reg
R.
100% CORRECT!!!!
iceracer Dec 22, 2005 11:35 PM
While we're at it, where is the cabin filter located on a 98 v70?
Thanks, Terry
tech Dec 23, 2005 09:54 PM
ORIGINAL: iceracer
Thanks, Terry
Yours is located under the plastic wiper cowl at the bottom of the windsheild on the left side.
Remove the 2 Torxes screws on the passenger side and lift the panel up and you can slide it out.
iceracer Dec 24, 2005 02:28 PM
Do I have to remove the wiper arms to get at it?
When you say; " left side" is that as you look at the car from the front or as you're sitting in the drivers seat?
thanks tech.
T.
tech Dec 24, 2005 02:44 PM
Sorry on the passenger side. No you don't have to remove the wiper arms.
Just lift the panel and you will see the filter.
JJH Jul 27, 2013 09:24 PM
where would the cabin air filter be in a 2000 s40. I bought the filter just don't know where it goes.
JJH Jul 28, 2013 12:29 AM
Cabin Air FILTER
I just bought a cabin air filter for a 2000 S40 but don't know where it goes or how it is installed....Please Help!:confused:
rspi Jul 28, 2013 05:45 AM
Try Google , lots of answers there.
