Cat Codes (and one other)
Old Apr 5, 2009 | 08:02 PM
bjornagain's Avatar
Default Cat Codes (and one other)
Hi all,
Have just had my first "check engine" warning light on my 1998 V70 non-turbo. My OBD2 software comes up with a P0420 code which, I believe, indicates a problem with the catalytic converter not operating at proper efficiency. We've recently had some road work done on our entrance drive and the grader operator changed the approaches to a culvert drain pipe which, unless you're really careful, scrapes the underbody on the culvert pipe. My question is, if there's been a bit of damage to the exhaust system from this scrape, would it affect the Cat? Is there any way of checking to see if that's the cause or if the Cat is just getting older. (The car has done nearly 250,000 km).
Also, how can I be sure that it is a Cat problem as I understand that this code can sometimes be triggered by the injectors getting a bit old and worn.
And ( the bonus question), I also got a P1080 code which I can't find a definitive answer for (differing websites and references give differing results!).
Any and all help appreciated.
Old Apr 5, 2009 | 08:06 PM
If you have a vacuum leak it could trigger that code.
Old Apr 5, 2009 | 08:17 PM
bjornagain's Avatar
Tech..
Any way of checking if it is a vacuum leak?
Old Apr 5, 2009 | 08:20 PM
Make sure all of your vacuum line are good. Including the one on the end of the intake behind the power steering pump if you have one.
Old Apr 5, 2009 | 08:23 PM
bjornagain's Avatar
Tech.. thanks for that
Any opinions on after-market (so-called "universal" catalytic converters)? Are they OK to install if mine needs replacment or should I stick with the real deal?
also, in my original question I asked if a bump or scrape to the exhaust system could cause that P0420 - is possible?
Old Apr 5, 2009 | 08:27 PM
I would try to stick OEM.
I doubt the scrape caused the code.
M3lonT5R
Sep 10, 2013 08:25 PM
Schaeffy
Aug 15, 2012 11:04 PM
stevenro64
Apr 19, 2011 05:23 PM
glewis1
Dec 12, 2008 10:50 AM
