Catalytic Converter Alert
I am trying to pass a Smog Check with my 2001 V70, but I keep getting a Catalytic Converter Alert from the Check Engine Codes. I replaced the Converter, but the code still appears. Anyone else with this problem?
Please post the actual codes when you're requesting help w/codes. Thanks. :)
And, your question would make more sense and be likely to get more people who know of and or worked on that problem if you included the code in the question (next time). IMHO
"Problem with cat converter code XXX" or "Failed emissions cat code XXX" What you posted made me look because I though there was a problem, like a recall or warning about a converter issue. |
| All times are GMT -5. The time now is 10:26 AM. |
