-   Volvo V70 (https://volvoforums.com/forum/volvo-v70-13/)
-   -   climate control (https://volvoforums.com/forum/volvo-v70-13/climate-control-933/)
watson6033 Feb 4, 2005 04:37 PM
climate control
All green lights are on in climate face, but blower motor does not run-either in auto or mamual. Any ideas?? Thanks
tech Feb 4, 2005 04:58 PM
RE: climate control
Sounds like blower motor/blower resistor.They blower motor is behind the glove box.You will need to remove the passenger side lower dash panel and the glove box.Check for power at the blower motor.If you have power there then the blower motor is bad.Most of the time when they go bad it overheats the resistor and it is best to replace that at the same time.
watson6033 Feb 7, 2005 02:30 PM
RE: climate control
Thanks tech-sounds like tough job for me-any idea how much a dealer would charge? Dave
tech Feb 7, 2005 03:03 PM
RE: climate control
The dealer is pretty expensive.It really isn't that hard I think you can do it.It should take you about 30-40 min to do it.
watson6033 Feb 23, 2005 08:49 PM
RE: climate control
tech-Got ready to remove blower and thought would give the system one more try--it workrd just-real mystery???? Stray electrons?
tech Feb 24, 2005 12:08 AM
RE: climate control
Will probably quit again soon.
