Engin Codes and Rough Idle
Old Mar 25, 2012 | 05:58 PM
SVolvoD4's Avatar
Default Engine Code and Rough Idle
Hey, I have a 99 Volvo V70 T-5 with 130,000 miles. I just replaced the alternator and after starting it up the check engine light came on. I pulled the code and it was P0134, that is the code for the O2 sensor, one of the front ones. Also, lately the car has been having a rough idle (drops about 200-300rpm) intermittently, and there is some white smoke from the dipstick. I am pretty sure the PCV valve is clogged up or the system is shot. I did the whole balloon-on-dipstick test and it didn't start blowing up the balloon (stretch the latex), but did put some smoke into it and made it stand up. The oil is really low (Just under quart low line), I think due to the pcv valve. Could it cause the O2 sensor to not function properly. Let me know what you all think, is it the PCV? Should I just replace the sensor? Thanks
Old Mar 28, 2012 | 12:21 PM
SVolvoD4's Avatar
Has anyone had a bad PCV system, or clogged valve before? Are there any other symptoms that usually happen with that?
Old Mar 28, 2012 | 09:46 PM
gdog's Avatar
Sounds like you need a PCV OH, new O2 sensor (ck this), and an oil change..
And since it's a '99, most likely one of these soon too.
Old Mar 30, 2012 | 03:21 PM
SVolvoD4's Avatar
thanks, is it possible for something else to cause the engine code though? And if the PCV fixes the rough idle, I think I'll wait on an etm, what would be symptoms of that going bad? probably an rpm problem and surging or something? just curious, why did you type 'PCV OH' what was the OH for?
Old Apr 5, 2012 | 10:19 AM
SVolvoD4's Avatar
Well I have my new PCV, I was just going to clean the valve, but the hoses look worn. I'll let you know what happens. Still, anybody know of other causes of the o2 sensor code, just so I don't have to buy a new sensor if it's not needed.
edwardh
Feb 13, 2011 10:21 AM
mehdimusic
Aug 21, 2010 06:51 AM
rooster11
Jul 14, 2009 01:23 PM
football coach
Dec 28, 2008 10:32 AM
BILL_MCCASSEY
Sep 27, 2008 02:22 PM
