Erratic catalytic converter code? p0420
Old Sep 3, 2008 | 01:52 PM
mr maraki's Avatar
Default Erratic catalytic converter code? p0420
First off, I've only read this with generic OBDII reader. I haven't had Volvo pull the code yet.
I will randomly get the p0420 code, months apart. The first time I got it coincided with an inspection due, so I just cleared it. It re-appeared ~3 months later. Cleared, about a month later it came back. Cleared, about a month and a half later it came back.
As far as I can tell, the cats are fine. The car has 112k miles on it. It seemed to coincide with the really hot weather beginning here in central Texas? Typically it will appear after about an hour on the road continuously.
Anything else this could be symptomatic of? Is it worthwhile to have Volvo pull the code, ie could it reveal more info?
Thanks for any help.
Old Sep 3, 2008 | 07:44 PM
Default RE: Erratic catalytic converter code? p0420
Maybe O2 sensor?
Old Sep 3, 2008 | 09:11 PM
mr maraki's Avatar
Thanks for the response tech, you're a huge resource! Do you know if Volvo will be able to see a separate o2 sensor code if it's there (as opposed to the generic p code I mean)?
Old Sep 3, 2008 | 09:21 PM
Yes they will. Most Generic scanners will only read half the codes stored in the S40's for some reason.
MarkS60
Sep 8, 2016 07:07 AM
jdyasin
Apr 12, 2016 09:03 AM
TacklaNHL
May 1, 2014 02:24 AM
fioramosca
Oct 7, 2010 09:14 PM
tr_car_nut
Oct 10, 2009 03:16 PM
