Error Code P0234 01 V70 2.4T
Old Sep 6, 2006 | 02:18 AM
Anns V70's Avatar
Default Error Code P0234 01 V70 2.4T
I am having a real issue solving an error code P0234. We have replaced the Map Sensor and found a crack in the vacuum tee fitting and replaced it as well. Thought the problem was resolved, but the over boost code resurfaced. I could tell the minute I hit the throttle and the turbo seams to jump off the line, but dies as the rpm reaches the next gear shift.
The strange thing is the sevice engine light will come off with time, but resurface down the road. The condition appears more common with the ac on. Any suggestions would be a great help.
Boyd[:@]
Old Sep 6, 2006 | 08:29 PM
Default RE: Error Code P0234 01 V70 2.4T
The Boost Valve might be bad.
Another Vaccum line might be bad.
Old Sep 7, 2006 | 11:53 PM
Anns V70's Avatar
Thanks Tech we will look it over this weekend and post our findings.
Boyd
hamburglar
May 9, 2013 11:30 AM
eewhiz
Oct 26, 2012 09:12 PM
mark458
Sep 29, 2010 07:34 AM
cowenstaff
Nov 2, 2009 06:00 AM
