ETS light Headache..
Old Sep 26, 2006 | 11:51 PM
ToddsV70R's Avatar
Default ETS light Headache..
Hello to everyone.... I am new to Volvo and this forum. I have a 1999 V70 R with 143,000 mile on it. Let me say first she is quite the sweet heart. Now for the bad news. My ETS light is on... The ETM was replaced in Feb of 2006, the software upgrade done in April 06. Just had the accelerator Pedal sensor replaced and now the ETM relay. All the wires check out fine. I need to find diag codes for this little bugger. I am kinda at my whits end here. Dealer says there is only one thing else they can do... Replace the ECM. but I think I have another bad ETM... Any ideas would be greatly appreciated. You folks rock with all the great info here....
Old Sep 27, 2006 | 12:02 AM
Default RE: ETS light Headache..
What codes is it throwing?
Old Sep 27, 2006 | 12:28 AM
ToddsV70R's Avatar
I am not sure the tech at the dealer said it too fast... P9810 I think... Sorry i cant be of more help... Car will not rev up in neutral... But seems to run fine other wise... Thanks for the response so quickly...
Old Sep 27, 2006 | 12:37 AM
See if you can get the code for me.
Also with the new software the Rev-limiter kicks in alot earlier and in Neutral.
To bad such high milage if it only had 80,000 miles you could have gotten it for free.
The ecm's are warrantied till 80,000.
Old Sep 27, 2006 | 05:12 PM
ToddsV70R's Avatar
It is throwing code 9180 Perm ECM code... Hope this will be somewhat helpful... Thanks Todd
Old Sep 27, 2006 | 09:40 PM
Ok here is the Info on the Code you have stored.
Sorry no real fault tracing I would pull out the wiring Diagram and start looking at it.
Sorry about the quality I have to take a pic of the computer monitor.
Hope this helps some.
If you need a wiring diagram look here. http://www.volvotechinfo.com/WD123/
Old Sep 27, 2006 | 10:07 PM
ToddsV70R's Avatar
Well Tech thanks... seems like its going to be either the ECM or the ETM Being as though this was just replaced in Feb how do you check to see if it is bad again. Are there any test that can be performed by a meter ??? Also does anyone know if you replace the ECM if it needs to be programed by the dealer ?? Also any ideas as where I can get one priced reasonabley or even a used one ?? Thanks for the info you sent... I'll await your response...
Old Sep 27, 2006 | 10:14 PM
Not that I am aware of for the Testing.
I would Ohm the wires about all I would know to do.
Yes the ECM needs to be programmed by the Dealer.
Most of the time A used one will not program you would have to buy a new one.
Maybe the only other thing I can think of but might be a waste of Money it to try to have a Cheap Upgrade done to your ECM by a place that does the upgrades. Like IPD RICA ETC
You never know it might or might not work.
Old Sep 29, 2006 | 10:20 PM
ToddsV70R's Avatar
Dear Tech,
I just purchased a used exact replacement ECU for my volvo V70 R. How do you go about switching this thing ??? Do you have any tips or did I screw up and buy something thats not going to work... If you have an idea of how best to remove the old one and replace the new one please give me your advise... Thanks Todd
Old Sep 29, 2006 | 10:29 PM
About the easiest way is to remove the Box holding the computers in. There should be one screw by the washer fill neck.
Then it should slide off. You might also have to push some clips to get it to slide up.
Then you will see Purple sliders at the base of the computers. They will need to slide one way to unlatch the computer.
Then slide the other way with the new computer in.
Old Oct 8, 2006 | 11:33 AM
BIGDAN's Avatar
If it is not getting a pedal signal it could be the ecm(the signal goes to the ecm) but why not try a pedal first. It is cheaper and easier.
my .02 worth.
Dan
Old Oct 9, 2006 | 12:53 PM
ToddsV70R's Avatar
Dear Dan,
Already replaced the pedal on my last trip to the dealer... I think I am going to have to replace the ECM... But the dealer says there are no test to check and see if its bad.Just throw parts at solving the problem... Thanks for your help... Any other ideas let me know... TOdd
Old Oct 21, 2006 | 01:33 AM
ToddsV70R's Avatar
Update on ETS problem:
Got the car back today from local dealer after having " Volvo Super Tech " spent a full day working the car over...... Problem... Replaced the ETM again... Got bad unit in Feb of 2006... Cost to myself.... $ 0.. Thank you to all who helped out with this problem... And Thank you Volvo.... for standing by your cars..... Great customer service.... Lets just pray that this unit will last longer than the last one... Thanks again Tech... Didnt forget your little gift.... WIll come shortly...
Old Oct 21, 2006 | 01:51 PM
I am glad they got it fixed with NO COST to you.
Thanks for the Gift (it hasn't arrived yet) but you didn't have to do that.
1998v70
Aug 16, 2015 09:13 AM
bradenoch
Jun 7, 2014 03:09 PM
Bowtie4Life
Nov 21, 2013 04:17 PM
TANDEM86
Jul 16, 2009 10:45 AM
QueenslandV70
Aug 15, 2005 11:30 PM
