-   Volvo V70 (https://volvoforums.com/forum/volvo-v70-13/)
-   -   Fuel pressure maybe??? (https://volvoforums.com/forum/volvo-v70-13/fuel-pressure-maybe-98301/)
rgierer Nov 8, 2018 09:26 AM
the car is a 1998 V70 T5 with 120k. First thing in the morning is starts, runs rough for a second and is fine. If I start it on short trips around town, it starts, dies then the second time I start it it runs fine. If I get in the car, turn on the key, then put on my seatbelt, before I turn the key to start, It starts first time every time.
i suspect the ignition on for a minute alllows the fuel pump to run a second to build up fuel pressure before I start car.
do you think this indicates fuel pressure regulator, fuel pump, or some vacuum hose being off? I do occasionally have a fuel smell after starting but not in a consistent or predictable way.
thoughts.
rg
firebirdparts Nov 9, 2018 07:01 AM
It certainly is suspicious. I have a 98, but I don't think I ever hooked a gauge to it. The 850's, my gauge will not fit them really because the port is pointed at the throttle cable wheel. There's not room. A tire gauge will fit the Schrader valve, but you really need a real fuel pressure gauge on there for this.
