rt325 |
06-06-2009 10:57 PM |
Immobilizer fries when the key is used to unlock doors
Car had and aftermarket alarm on it, wife hit the unlock button nothing happened. So she hit it again same thing. Took the key unlocked the door, then the Volvo alram (which we had never heard) started going off. She immediatly put the key into the ignition to reset the system and it did nothing, alarm still going off and car would not start. When I returned home I figured the aftermarket alarm had failed so I had it removed by the same shop that had installed it. That did not fix it, but after much effort found the immobilizer box ( alarm box ). It was fried, you can smell it when you open the case. Went to a few salvage yards found one put it in. Car fired right up as if nothing had ever happened. Drove it to church and locked the doors (duh) thinking nothing of it. Came out afterwards turned the key and whamooo... Alarm goes crazy and it again fries the box. Found another box it is in the car and I am driving it now, I just will not lock it until I believe it is fixed. The only thing that I have been able to relate this problem to but not solve is the fuel door release stopped working a few days prior to the first time this happened. The door release test good with 12v to it, and I replaced the switch just in case. Please tell me some one out here has a clue about this. ANY AND ALL HELP IS APPRECIATED. Not really a good plan to leave a car unlocked in Houston.:confused:
