-   Volvo V70 (https://volvoforums.com/forum/volvo-v70-13/)
-   -   Internal temp problem (https://volvoforums.com/forum/volvo-v70-13/internal-temp-problem-19075/)
v70dave Apr 7, 2008 02:25 PM
I have a 2000 W Reg SE I have a problem with the temperature in the cab it does not seem to be able to keep the desired temperature set on the controls is there a sensor that monitors etc is this a common problem ?
billofdurham Apr 7, 2008 04:55 PM
RE: Internal temp problem
If the car is fitted with the Electronic Climate Control system then there is a passenger compartment temperature sensor. It sits behind a louvred panel on the dash,to the left of the ECC panel.
To get to it:
Ignition off.
Remove the radio.
Put your hand through the radio compartment and push out the ECC module.
Now put your hand through the ECC module opening and push out the switch next to the louvred panel.
Again working through the ECC module opening press together the catches holding the temp sensor in place and pull it backwards. Note the position of the sensor before you remove it.
Disconnect the sensor.
Refitting is a reversal of the above.
You will need to check if any diagnostic trouble codes have been stored during the repair work.
v70dave Apr 9, 2008 01:48 PM
Is this procedure for the mk 2 v70 mine is a year 2000 mk 2thanks for the help so far.
