-   Volvo V70 (https://volvoforums.com/forum/volvo-v70-13/)
-   -   Lights out (https://volvoforums.com/forum/volvo-v70-13/lights-out-21330/)
ldsafety Jul 5, 2008 03:59 PM
Lights out
I have need to run "lights out" in my job and was wondering if there was a Daytime Running Lights relay I could modify or switch out to accomplish this. I've done this on other vehicles and was able to use lights normally. Any suggestions?
Thanks
tech Jul 5, 2008 06:18 PM
RE: Lights out
Dealer or a Volvo specialist that has the Volvo software.
It needs to be done through Volvo's computer system.
alicia1972 Jul 6, 2008 07:41 AM
RE: Lights out
You can manually set the daytime running lights off in the 1998-2000 models. There's a small "flat head" screw located on the lower right hand corner next to your headlight switch on the dash. If your daytime lights are on the screw will be in a verticle position. Use a small screw driver and turn the screw to the left to 10 O'clock and this allows you to disable the daytime running lights
JRL Jul 6, 2008 01:10 PM
RE: Lights out
It would sure help to know what year Volvo you have
