Molding?
Old Jan 28, 2008 | 06:45 AM
psevigny's Avatar
Default Molding?
Hi, I tried to do a search on this topic with no success, maybe I am not using the right word for the part, I don't really know what is the real name for it...
I just bought a 2004 V70 with the 2.4, eveything is great except one small thing...It seems that the "gutter trim" or the roof molding that goes from the hood to the back of the wagon is not attached/clipped properly. When I pull on the part that covers the windshield, I can easily see under, in other words, it's loose...I see some sort of a blue clip under, try to push on it with no success...BTW, I don't get any wind blowing inside the cabin...
Anybody know how to fix that?
Thanks
Old Jan 28, 2008 | 05:54 PM
Default RE: Molding?
You will have to replace the clips.
Old Jan 28, 2008 | 06:40 PM
psevigny's Avatar
Do you think it's something I can do by myself, or should I leave it to a my volvo mechanic....because I don't want to break anything right???
Old Jan 28, 2008 | 06:42 PM
It really isn't all that hard but you might want to have them do it.
Does it have the roof rails on it?
If not and you are thinking about adding them now would be a good time.
Old Jan 28, 2008 | 06:48 PM
psevigny's Avatar
No, adding the rails is not something I want to do, I am really happy with look of the car as it is...plus I have enough storage for my skis and others in the trunk...The only clip I would have to replace would be the one that is in the middle of the windshield / passenger side.....How should I proceed ? Any clue ?
Old Jan 28, 2008 | 06:59 PM
I believe there is 3 there.
Also you might want to buy the kit. Because when you try to lift up high enough to replace the clip one of the others might break as well.
Old Jan 28, 2008 | 07:04 PM
psevigny's Avatar
Do you know what is the exact name for these parts, I'm trying to find these clips on an online parts store...and what store would you suggest for parts ?
Old Jan 28, 2008 | 07:08 PM
Not sure if you could find them online you might have to get from the Dealer.
That molding is usually called the Drip rail molding.
Old Jan 28, 2008 | 07:12 PM
Ok I just looked up the Volvo part #
The white clips are 30678009 there is 6 of them.
The blue clip should be 9190981 one per side.
psevigny's Avatar
Thanks a lot for your help!!! I think I will give it a try....
mightyjak
2001-2013 model year XC70
Jan 14, 2014 05:24 PM
crazynlazycolombian
Mar 20, 2006 09:38 PM
computowne
Feb 23, 2006 12:57 PM
jstarman
Jan 13, 2006 12:14 AM
etype38
Jun 15, 2005 12:37 AM
