P0505 code
Old Jun 7, 2008 | 08:01 PM
  #21
sporky's Avatar
Default RE: P0505 code
FIXED!
After replacing the intake hose and elbow my engine idle smoothed out and the P0505 code hasn't popped up...yet. Must have had some pretty bad air leakage around the flame trap.
Old Jun 8, 2008 | 07:00 AM
  #22
Glad all is fixed.
Old Apr 4, 2011 | 08:05 AM
  #23
brianluigi's Avatar
I have a 1995 Volvo 850 GLT NON TURBO 2.4L.
The p0505 came up on my phone through the golink cable. It states that it's the IAC system. So I hope I can find the cause. I'm trying to become a tech but I'm just learning.
Old Apr 5, 2011 | 03:22 PM
  #24
chippe's Avatar
Default code p0505
Originally Posted by sporky
Just got back in after removing the IAC and cleaning it with a solvent and rechecking the hose fittings. Plugs are not switched around. After unplugging the battery for a bit and then restarting, the code doesn't come back on for a few miles and only after I shut the car down and restart. The light flashes about 15 seconds after restarting. Not sure, but it seems that the light comes on after the restart when the idle settles and the tach drops below 1000 rpm.
Any way to tell what Volvo code the P0505 from the Actron scanner equates to?
the code on autodata brings up wiring,isc actuator/iac valve,throttle motoe.throttle valve tight/sticking,ecm hoppe this helps
Landon Kaufmann
Apr 30, 2013 06:24 PM
slimflex2
Aug 16, 2012 11:51 PM
brian.keith
Aug 31, 2010 05:59 PM
badmonkey
Jul 28, 2008 09:15 PM
gzh
Mar 21, 2007 09:29 PM
