Rear Rotors and pads
Old Mar 25, 2009 | 05:23 PM
tiredman68's Avatar
Default Rear Rotors and pads
Hey i'll be working on a 1998 v70 cross country tomorrow and am wondering how exactly i need to go about replacing the rear rotors and their pads...is there a certain walkthrough i could use along with what tools are necessary? I havent seen the discs, but from what I know I need to do is use a [allen?] wrench to unbolt the calipers(after the car is raised and the wheels off) and disconnect the brake line? From there on I'm lost unless the rotors slide off and if the pads are self explanatory...
any help would be much appreciated..thank you
Last edited by tiredman68; Mar 26, 2009 at 07:44 PM. Reason: Year was wrong and its a cross country
Old Mar 25, 2009 | 07:07 PM
It is all straight foward. The front's you will need a 7MM allen to remove the caliper. A 15MM to remove the caliper bracket. Then the 10MM for the little screw through the rotor.
The rear you will need a punch to remove the pins to change the pads. Then a 13MM to remove the caliper and the 10MM for the little screw.
Old Mar 25, 2009 | 08:46 PM
Johnny Mullet's Avatar
Yeah, it's not too bad. Good luck!
Old Mar 26, 2009 | 07:46 PM
tiredman68's Avatar
ok so i tried today and had not luck. It is actually a 1998 V70 Cross Country (AWD) i was mistaken earlier. I didnt find anywhere to use the allen or the punch.. I managed with a 13mm... I unbolted the four bolts, two to the rotor and two to the caliper... it came off (the caliper) but the rotor is still stuck.. how and where to i clamp (with a c clamp) the brake likes? is it in the hood or by the caliper and what do i do? the rotor wont budge from the car...
thanks!!
Old Mar 26, 2009 | 07:53 PM
JimKW's Avatar
Probably not using a big enough hammer if all the bolts are out. Those suckers can be stuck. I have never done an AWD though.
Old Mar 26, 2009 | 08:05 PM
Make sure the e-brake is off and hit it harder.
Ok the AWD does not use the pins.
DugB
1998-2000 model year XC70
Jul 22, 2013 09:05 AM
grndslm
Jun 30, 2012 02:44 AM
snowtyres
Nov 25, 2011 09:47 PM
Calita03
Jan 8, 2009 03:39 PM
indagutter
Jan 5, 2005 01:57 PM
