removing kick panel to replace blower
I will need to replace the blower motor soon and I can easily remove the glove box but can't for the life of me find the torx screws that remove the lower kick panel. I think it is different on my 2000 v70 than on an 850, which is covered in the Haynes Manual. Also, any trick to removing the glove box hinges?
thanks Gene |
RE: removing kick panel to replace blower
The Hindges there is a notch in the door use a small pick in the hole to release.
Once the glove box insert is out you will see 2 or 3 screws holding the kick panel on. |
Thanks! Found them. I can also see them throiugh the partially opened glove box door where they hold the kick panel tabs. Different setup than the 850.
Thanks Again |
| All times are GMT -5. The time now is 07:09 AM. |
