Repaired ABS Module
Hi
I just received my repaired ABS module for my 99 V70.
Install was as easy as removal however,
I am still showing an ABS and Traction control light
I was told it can take around 50 miles for the system to reset itself, is this true?
Many thanks
Many thanks
Hi
I just wanted to post that I solved the ABS issue-
I turns out that After installing the abs module - I was still getting the code
so I traced the fault to a cut in the passnenger's front sensor wire-!
Doh!
Doh!
