Sizing on Rims/winter tires for 2005 V70
I am driving out of town to pick up a set of rims and winter tires for my 2005 v70 turbo, 2.5.
Currently, my car has this tire size: 235/45R17 The rims I'm looking at are sized as followed and have the tires mounted on them already: Rims: Bolt Pattern 5x108 mm Hub Bore 65.1 Nut or Bolt bolt Nut Bolt Thread Type M14x1.5 Nut Bolt Hex 19 Bolt Length 27 Minimum bolt length 26 Nut or Bolt Torque 103* Tires: 215 55 16 From what I've been able to find, they look like they should fit. Any input here? I am no wheel/tire expert and don't want to make the drive and pay the money to store them. I'm pretty sur they are coming from a 2000 v70 Thanks, Dan |
You should find a tire size calculator online to determine if the size you are looking at will be close in total sizing for MPH. Pretty sure though the Volvo 16 inch sizing for the 235/45R17 is 205/55R16.
Check out wheel-size.com - It has ALL the info you need down to center hub diameter...
