Standard boost
Hi i recently bought a V70 T5 1998 in whitefor £100 (absolute bargain). I had to replace the steering rack 2 rear shockers and a rear break caliper. Got the car on the road for £600 in the end that included taxing, mot and buying it so well chuffed.
Now the question is what boost do they run standard? I would also like to fit a boost gauge but would like to know how big of a job is it to do and if anyone has fitted one could they give a brief description.
Thanks in advance Jimmy
You should be around 7-10 psi boost.
The boost guage isnt bad at all. You need to mount it then run a vacuum line to outside to the intake manifold.There is a tube of the corigated looking insulation that goes from inside to outside that allows you to run the line through.
