starts hard afterfilling gas tank
Have 2000 V70 station wagon, non turbo. After filling it with gas it start only after pumping the gas pedal repeatedly. Than runs rough for 30seconds or so. Than runs great till the next fill up. Removing the gas cap doesn't cause the same problem. CEL is on. Code says gas/vapor recovery system has a leak. Thanks
3 Attachment(s)
Originally Posted by Skua
(Post 338764)
Below from '95 850 manual but yours should be similar: FUEL EVAPORATIVE (EVAP) EVAP Valve Check 1) Disconnect ventilation hose and canister guide from throttle body. Connect vacuum pump to ventilation (large) port and begin pumping to obtain partial vacuum. See Fig. 5. Even though pressure returns quickly to atmosphere pressure, resistance should be felt when pumping. 2) If vacuum and resistance are okay, go next step. If vacuum cannot be reached or resistance is not okay, check ventilation hose connected to canister for damage or leakage. If hose is okay, repeat test using new canister. Fig. 5: Checking EVAP Valve Courtesy of Volvo Cars of North America. 3) Apply vacuum to small vacuum port. If partial vacuum is present, go to next step. If no partial vacuum is present, check vacuum hose connected to canister for leakage. If hose is okay, repeat test using new canister. 4) Maintain vacuum in vacuum hose. Blow into hose that fits into large port. If air passes through canister with slight resistance, canister and guide are okay. If air does not pass through canister, check vacuum hose for blockage. If vacuum hose is okay, repeat test using new canister. |
codes,
P1670 And P0440 |
