stuck shock retaining nut
Anyone got any tips on how to remove the cross-shaped front shock retaining nut? Can't remove the coil until I get this off...probably needs a special tool, but I don't have it....help! thanks
2 Attachment(s)
Try to break it loose with a pipe wrench before compressing the spring.
I made this to loosen the nut. Attachment 22621 Attachment 22622 |
Ah...nice solution with that socket you made! Hmmm...might give that a try...thanks tech
Let us know how you make out.
Hold the nut on the shaft with a box wrench (8mm?) and use a large crescent wrench (or pipe wrench on the nut. Tap the small wrench with a hammer to loosen. The impact should break it loose... worked for me.
