-   Volvo V70 (https://volvoforums.com/forum/volvo-v70-13/)
-   -   Turbo feels patchy (https://volvoforums.com/forum/volvo-v70-13/turbo-feels-patchy-9587/)
v70 2.4t Jan 15, 2007 05:01 AM
Turbo feels patchy
Hi Guys, changed the oil & oil filter last Monday.
car ran really well that day, Turbo was pulling hard the way it should.
Yesterday while driving, especially in first gear, the Turbo feels
patchy, like a untuned carby. and ideas would be good.
I'm not blowing any smoke, no codes, no exessive turbo whine,
just the hesitation from the turbo
likely causes:
Fuel filter? (when should you change it)
Air filter? (when i inspected the Air panel filter it has a gouge out of the rubber seal on top would that make a difference)
Spark plugs ?(how often should you replace)
thanks
v70 2.4t
tech Jan 15, 2007 09:04 PM
RE: Turbo feels patchy
Plugs and filters every 30k
Check all the vaccum lines.
v70 2.4t Jan 18, 2007 01:34 AM
Would oil pressure play a part in this!
v70 2.4t
tech Jan 18, 2007 08:44 PM
Might but I doubt it.
v70 2.4t Feb 5, 2007 08:25 AM
Oil feed line to the turbo had a split in it, oil leak fixed, oil gasket, inner o-ring, outer o-ring all replaced...running good and turbo boosting the way it should :)
v70 2.4t
JimKW Feb 5, 2007 11:19 AM
I really like it when somebody follows up with a post on what they did to fix a problem and whether or not it worked. Who knows that might help somebody with the same problem. Glad you got it running good!
