turn signal bulb socket 2001 v-70 not the lens
while replacing the bulb in dr. side front turn signal I cracked the socket that the bulb fits into if it were only cracked I'd fix it but it is in 2 parts. This is the part that holds the bulb and 1/4 turns into the headlight assembly. anyone know where I can get a used one. The dealer is going to charge me arm + leg for a new one.
If it's a standard 3157 or 1157 bulb socket, you can get replacements at most parts stores, but the way they are molded to fit the lens is not always the same. A little trimming usually makes them fit.
Thanks mullet, you da man.
it's not that bad, i need this too, dealer quoted $11.
