V70 [2010] rear fog light replacement
Hi!
the rear fog bulb should be changed.
I checked user manual without success. Only turn signal bulbs replacement is decribed. How to change rear fog bulb ? I saw screws on the inside panel of the tailgate but don't know if this is the right procedure.
thank you in advance
Flamel
Flamel
Page 226 of this manual: https://customers.volvocars.com/owne...nersManual.pdf
You have to pull a panel off fron inside the cargo area to see the back of the bulbs.
As I said in a previous email, the rear fog bulb is not with the turn signa bulbs . It is on the mobile tailgate with other bulbs (backup lights,brakes light) . I read the user manual but it is incomplete. No explanation about how to change bulbs located in the tailgate part.
And Yes I'm sure. I have an information message on the dashboard each time I try to push on the rear fog light:
>> rear fog bulb should be replaced <<
regards
Flamel
HelgaTheS80
03-09-2007 03:20 AM
