V70 AWD Engine swap. HELP!!!
yo!
I've got a v70 awd on a 98. The engine went on it and i sorced another one and got it fired up. The problem is all in the plumbing. I cant seem to find all the correct positions for the vacuum hoses. the car is jerky and doesn't drive that well. Also the kickdown seems as though its not working and its generally sluggish. Any photos of the engine bay in detail would help a great deal. The engine is a 2.4t (B5254t). The lights for the engine electronics is also on....? Please help! Thanks in advance! |
RE: V70 AWD Engine swap. HELP!!!
Did you set the lines by using the diagram under the hood?
Is the throttle cable adjusted properly? |
Thanks for the reply...which diagram under the hood? Where do I find this diagram? Yes the throttle cable is adjusted ok I think...
Unless the hood has been replaced on the passenger side on the hood close to the windshield there should be a white sticker with all the info on it.
I live in the uk and i couldn't find any diagram. iwas wodering if i could get a diagram of the vacuum pipes. i think i only need to know where the thin two pipes go from the air filter pipe to where? and the thin pipe from near the turbo an the right if you face the car...
any ideas why the triangle comes on the dash after start up....??? |
The triangle should be the lamba light in other words check engine light. Means there is codes in the engine module.
Can you take pics of the hoses you need to know about? |
