Hello all, I'm purchasing a 2012 XC60 T6 AWD R-design and if comes with 20" wheels. Could anyone verify whether or not a set of 17" wheels and winter tires from an S80 will fit? Thanks, Ken
wheel-size.com is my go to resource for swapping rim questions. Generally speaking if the S80 is 2008 or newer they will fit as they'd both have the same center bore - the only minor nuace to check will be the offset. If its within 5 mm (1/4 inch) you wouldn't notice.
