2013 XC60 Catalytic Converter
I recently purchased a used 2013 XC60. Engine light came on and Volvo dealer says the catalytic converter is bad. Dealer wants to charge $6000 to replace. Should I just buy the $1500 Volvo OEM part and change it myself or are there any other options? I don't want to buy an aftermarket catalytic converter and do all that work and find out I still have an engine light on.
I'm going through the same issue with my 2010 xc60 t6.
I tried Cataclean a few days ago and so far, the check engine light is still on.
So it may not be the cat.
A few opinions suggest that it may not be the cat but other parts. Below is a Volvo forum member's response to my issue.
"If you are getting fumes in the cabin you have an exhaust leak, which is a likely cause for a cat efficiency CEL code. Most likely you can hear the leak - like around the flex pipes but could also be a cracked manifold, a disconnected EGR tube, a broken exhaust flange etc. Address that before you blame the cat :-)"
Good luck with your issue.
So, I'm going to see the mechanic today... should be interesting. Update to follow
Some codes will - if you leave your gas cap loose - that code will go away if it tests ok the next time (after you tighten the cap)
Fyi, I don't have fumes in the cabin, bad gas mileage, or poor engine performance either. I installed a brand new OEM gas cap before the dealer checked out the car. So that is good too. Car is still running pretty good.
Thanks for any guidance.
