low beam bulb failure
Dear All:
My 2013 xc60 had "low beam bulb failure" message and it is on passenger side. My low beam is factory HID and high beam is halogen.
After I start my car, low beam light would stay on for about 1 minutes or so, then flash on and off three times, then stay off. My side marker light on passenger is not working either.
I have used new bulb and working ballast to confirm that neither of them causes the problem.
All the lights on driver side are working, high beam and signal lights of passenger side are still working.
What else could go wrong? If possible, could you share fuse and relay diagram?
Best regards
Best regards
