Power Window Switch Auto Feature Stopped Working
My 2012 XC60 on the drivers door power window switch three of the four power window switches "auto" feature stopped working, you can raise and lower the windows just the "auto" feature doesn't work, the only switch that works is the passenger side front door the "auto" feature works fine for that door. This started after the battery drained when I was using the ignition II, I jumped the vehicle not sure if this had anything to do with it may be coincidential.Is this a dealer service repair or is there any special trick that I can do to fix? Thanks, any help is greatly appreciated.
Just a follow-up, the power window switch auto feature started working again, not sure what I did, but it started working again.
My auto up & down isn't working on any window. The car sat for a month and the battery went dead. I charged the battery and all seems good but the auto up & down function. Anyone have any ideas?
Originally Posted by terryd4
(Post 427995)
Hold the button down and let the window down all the way. Then hold it to go all the way back up. That should solve the problem. Mine did the same thing and that was what the mechanic suggested and it worked.
Originally Posted by JBxc60
(Post 444230)
This happened to me after a flat battery. The internal light that automatically comes on when I remove the key fob stopped working as well. It is now working again and I'm not sure what I did to make that happen. If anyone knows maybe they can add it to this thread as they both might happen regularly together after a flat battery. |
Originally Posted by 09MY10VolvoXC60
(Post 478140)
I just figured it out. This is correct but additionally you have to hold in in the down and up position for at least 1 second after it reaches the end and then release the button. It will then reinstate the automatic function. You need to do it for each window.
On my wife's 2008 S60, the automatic window is Not working properly, when the window goes up it doesn't stay closed, it reopens the window unless you hold the button on the up position..
I tried holding the button on the up position as suggested but unfortunately didn't work.. Any suggestions? Thanks in advance! |
