-   Volvo XC60 (https://volvoforums.com/forum/volvo-xc60-51/)
-   -   Resetting tachometer and speedometer (https://volvoforums.com/forum/volvo-xc60-51/resetting-tachometer-speedometer-84330/)
terp Jun 22, 2015 03:23 PM
2 Attachment(s)
Hi everyone,
Hopefully someone here may have some experience with this as I have not been able to find any help through google.
I have an 2011 Volvo XC60 and earlier this morning I was driving it to work at a decent speed when I hit an unexpected bump. It didn't see to be a very big jolt to the car, but I noticed that the electrical system in the car shutdown for a second or two all while the engine stayed on and I roughly maintained the speed I was cruising at. The system came back on by itself and everything seemed to be working. Everything except the speedometer and the tachometer which were reading higher spped and RPM then what I could tell the car was exerting. When I got to work I shut off the car and noticed that when the engine was off and the car was parked, the RPMs would sit at 30 and the kmp would rest at 20. Again this is with the engine off! Now when the engine is on the RPMs hop up to about 42. I believe the problem is that the gauges have been mis-calibrated when the system restarted as the car does not seem to running with a higher RPMs. It now seems that the gauge considers 30rpm what normally would be zero rpm.
I saw on this thread for another make and model car that this may be because of a spike in electricity or a battery being replaced. I think that maybe this is the case here but I am not sure.
Any thoughts on how I might be able to reset tachometer or maybe what else could be causing this issue?
Thank you!
P.S. I've attatched images of the gauges with the engine both on and off. The lower RPM pic is with the engine off and the higher is with the engine idling.
Grizzleydog Mar 23, 2022 01:58 PM
Terp
Originally Posted by terp (Post 413958)
Hi everyone,
Thank you!
I have the exact same problem. I see there's no reply to your question.
Did you end up sorting the problem?
If so, how did you do it please?
hoonk Mar 23, 2022 02:23 PM
You may have a bad DIM (the instrument cluster) . Speedo and tach problems are a common failure. Symptoms courtesy of xemodex.com
https://xemodex.com/us/product/instr...-for-volvo-p3/
https://cimg3.ibsrv.net/gimg/volvofo...39014ab3fb.jpg
Grizzleydog Mar 23, 2022 02:36 PM
Thanks for that. My reason is a tad different though.
My positive terminal fuse blew when I was on the motorway. Instant cut of power 100%. That's why the needles still read wrong because they were sitting at where I was cruising when it dies. Now I've replaced fuse..the needles are out. Do you know how to reset needles to normal?
hoonk Mar 23, 2022 02:48 PM
Sorry, don't believe that's possible, your needles are not going to get stuck because you blew a fuse. There's an electronic problem with the instrument cluster.
terp Mar 23, 2022 02:58 PM
Disconnect the battery
If I recall correctly, I had to disconnect the battery for about 15 minutes and then reconnect it. Doing so reset the meter to 0. Good luck!
Grizzleydog Mar 23, 2022 03:15 PM
Thank you, but I have tried this and no result sadly.
Grizzleydog Mar 23, 2022 03:17 PM
Unfortunately it's the case.
Is there an instrument cluster fuse that might be blown? Or does one fuse run the whole cluster? Im hoping theres a specific needle fuse.. but then again theyre still working , just not going back to zero
hoonk Mar 23, 2022 05:50 PM
I don't believe it is possible to "reset" the needles not that your situation is not possible. There is a fuse in the CEM for the DIM, have you checked that? I only have LHD wiring diagrams, I hope the location is the same. Wiring diagram also show a relay in the circuit, but its not listed separately - (it's inside the 4/56 dashed line box on the diagram) - that means it's internal and part of the CEM. (not replaceable by itself)
https://cimg7.ibsrv.net/gimg/volvofo...aa087ebac6.jpg
https://cimg8.ibsrv.net/gimg/volvofo...753c3c8f19.jpg
Grizzleydog Mar 23, 2022 06:28 PM
thank you very much. Will check
