S80 rims on an XC60?
I’ve got a 2010 XC60 with 18” rims. I have a set of 18” rims taken from a 2010 S80 that I would like to use on the XC60 for snow tires. The S80 rims have the same bolt pattern and the same offset as the XC60 rims. Is it safe to use the S80 rims for snow tires?
wheel-size.com is a great resource for rim questions. Mostly Volvos have five lug rims (exception being the older models and the gen1 S40) in a 5x108 pattern but the center bore changed in 2010 or so (excepting for the gen 2 S40s which had the smaller diameter as well). So the only thing to know about moving rims from model to model is the correct offset and general size, which is where the web site helps...
Thank you. That is a very helpful site. Glad to know about it. Much appreciated. it looks like fit will not be any sort of issue.
But I also wonder whether the S80 rims are sufficiently beefy, given the additional weight of the XC60. All of the information I have found about this issue pertains to tires rather than rims.
