Wheel wobble
I am used to drive cars with good balanced wheels. On the highway I am used to have a steady feeling in the car/steering wheel.
I am now driving the XC60 with 255/45 R20 Tyres.
So a relatively flat tyre. Is it normal that such tyres/wheels give a more bumpy feeling less comfort?
It drives still good and I feel no unbalance, but the car is just not steady on the highway. A light bumpy feeling in the car on certain roads.
Does anyone recognize this?
wider tires combined with poor alignment can lead to "nibbling" - where the tires tend to follow cracks or ridges in the road surface. When was the last time you had the car in for a 4 point alignment? When you take the car in, make sure you ask for the results print out as well that shows all the suspension measurements. It is also possible you have something worn or bent in the suspension - a proper alignment shop should inspect when they put the car on the rack.
[QUOTE=mt6127;504064]wider tires combined with poor alignment can lead to "nibbling" - where the tires tend to follow cracks or ridges in the road surface. When was the last time you had the car in for a 4 point alignment? When you take the car in, make sure you ask for the results print out as well that shows all the suspension measurements. It is also possible you have something worn or bent in the suspension - a proper alignment shop should inspect when they put the car on the rack.[/QUOTE
is new car less than month
