Wire hanging below vehicle 2011 XC60 3.2
Yes an O2 sensor issue can cause a P0420. The P0420 is for catalytic converter efficiency - which is measured by comparing the signals from the rear O2 sensor with the front sensor. Other causes are fuel trim issues (ie fuel pressure too high, wonky temp sensor), exhaust leak, bad cat converter. Considering your wire dropped down, you should check for an issue with the sensor associated with that wire...
robinsonparker
02-09-2015 06:26 AM
