XC60 R-Design 2022 wont start when cold
I leased a new XC60 R-Design 2022 a few months back and I have been plagued by problems since the start, mainly software related, losing audio completely (even the indicator sound), google assist not working, maps being glitchy after a software update etc. and lets not talk about the Volvo App simply not working......these have all been software related and although annoying I can sort of live with them whilst Volvo sort out their less than perfect 'new' google OS.
My latest issue is causing me a lot more concern:
There has been 3 occasions when the car simply wont start, all the electrics are on and working but the error on the dash tells me I need to rotate the start button!! really! you think?
What I had noticed the last 2 times was the temperature was below 5 degrees. once it gets to 5 degrees it starts no problem (not sure if that is coincidence or an indicator of the problem)
I would appreciate advice from anyone else experiencing these problems.
Thanks in advance.
Thanks in advance.
I employ a sizable number of applications in my profession. And I make a point of only using good ones. And in doing this, I have the assistance of experts who are competent; you may learn more about them here and decide who to hire. Typically, I collaborate with a here business because I believe it to be the most trustworthy of its rivals. Additionally, I always received high-quality information products from them when I requested them.
Thanks in advance.
Thanks in advance.
What version of the software are you running?
Some of the problems describe are similar to v2.5 or earlier.
Edit: Just noticed the original post is from November 2021. So probably version v1.01 of the software at the time. An upgrade should have fixed it. Can OP confirm?
