XC60 T6 2018 - Accessory belt replacement
Old Feb 15, 2025 | 09:43 PM
Padington_Qc's Avatar
Default XC60 T6 2018 - Accessory belt replacement
Hi guys,
After noticing a more than anoying high pitch acute sound at cold start, like -15 deg C cold, I guess it's time to change my accessory belt. (154k kms)
However, being new in the Volvo fellowship, I'm not aware of any recurent or particular problem(s) on that model.
Since I'll be in the belt area, should I take the opportunity to look at some specific parts you might think of ?
Thanks in advance !
Old Feb 17, 2025 | 04:29 PM
with any drive belt, check the service interval recommendations regarding replacing the tensioner and pulleys. you can also feel around to see if any components feel off. You can also inspect for any possible leaks/weepiness/loose cracked vacuum hoses etc but at 100K miles, I wouldn't expect anything major.
Old Feb 22, 2025 | 07:31 AM
Thank you for the response !
Best,
PAD
jfirexc60t6
Nov 21, 2022 07:59 PM
kublaiboy
Nov 19, 2022 06:53 PM
DadBod
Nov 22, 2021 03:41 PM
cherry_carter
Oct 22, 2018 04:34 PM
Oakplank
Mar 28, 2018 09:55 AM
