04 XC70 Front lowbeam out, CHECKED ALL fuses
My 04 XC70 front passenger low beam went out the other day. I checked the bulb that was replaced about 5 months ago, and all is fine. I took out the right low beam and tried, still nothing. I've checked ALL the fuses under the hood and in the drivers side door and none are blown.
Any ideas? MUCH thanks! Paul |
RE: 04 XC70 Front lowbeam out, CHECKED ALL fuses
Headlight relay maybe??
Are they HID's or regular bulbs? If it is the HID's the ballast might be bad.
Good point! I forgot about possible HID's. Guess my CRS is acting up again <grin>
They are HID bulbs, I'll check the ballast. A good way to check to see if they are bad?
Thank YOU! |
swap it with the other one and see if it works.
ORIGINAL: b5254t swap it with the other one and see if it works. |
I noticed that i've been going through head lights about every 4 to 5 months thought it was odd but thought again because of the day time running light there are always on. common or uncommon?
I have this similar problem on my 03 xc70. I replace the drivers side light almost every 5 months. I will check the fuses but aside from that I am not sure what else to do. Any help?
Volvo XC70 oem ballast fail
Originally Posted by frusyks
(Post 111009)
Thank YOU! Wish can help you. Good luck. |
