2004 XC70 5cyl timing belt
HELP.. During the process of cleaning the PCV system that was totally plugged forcing oil past the cam seals we had the timing belt slip off prior to having the crank and cams on there marks. We decided to have Volvo dealership replace the cam seals which would require that they replace the timing belt and align timing marks properly. We have not turned the engine over yet because the left cam mark is off by about 45 degrees as received from them.
Any suggestions? Thanks, joejoe22 |
Welcome to the Forum.
Welcome to the forum. :) Moving to appropriate forum.
