Abs light & Tracks light problem
I was driving along and suddenly both lights appeared on the dashboard at the same time, is this because i have uneven tires or is it something else or what's your opinion on this. Thanks!
I will bet your ABS module is bad.
Search on eBay for xc70 abs and look at the companies that rebuild the ABS modules. It's about $100 for the exchange. You will need to pull the unit off of your ABS unit and send it to the company to have the internal solder joints fixed. They will guarantee it for life and it really does work. The toughest part is removing the little bolts that hold it to the ABS unit (external torx bolts - so weird).
| All times are GMT -5. The time now is 08:22 AM. |
