A/C Problem
Old Mar 5, 2021 | 01:33 PM
kaleyn's Avatar
Default A/C Problem
So twice now my A/C won’t blow cold air after having the heater on for weeks, except if I run the defroster for a day or two then the A/C will blow cold air again. Any ideas on what might be causing this issue?
Old Mar 5, 2021 | 02:45 PM
When it is no blowing cold - check to see if the compressor clutch has engaged and if so - the low side pipe will be cold (the bigger of the two ac pipes) and the high side pipe will be hot - sometimes too hot to touch. Low side should be 40 degrees or so -
Hkusp45
Jan 25, 2018 02:09 PM
shamrock777
Aug 7, 2010 09:24 AM
easilyamused
Feb 2, 2010 10:09 PM
solarman
Sep 18, 2009 07:06 PM
snkpkp
May 13, 2009 08:52 PM
