the dreaded clunking noise
2000 xc at 0-25 mph the dreaded clunking noise from rear of car . mostly is all the time seems worst after car warms . happens when speeding up and slowing down . driving straight or around curves ,also seems that the AWD is not working. I read alot about disconnecting the drive shaft . Is this the drive shaft ,v/c ,angle gear making the noise ? Can I disconnect the drive shaft in fornt or do i have to remove it conpletely ? Pls help
Figure out which wheels are still being driven by putting the car on a lift or jackstands. You may also be able to see some movement during the clunk.
Remove the driveshaft entirely if AWD is broken and you're not going to repair it. The angle drive can go bad. How many miles on the car? |
Nowadays everything goes around the clock. Technology at a maximum speed evolution offers the solution for a maximum speed efficiency of work. Nothing can be done without having a computer and most of all without having constantly connection and access to internet provider. The latter offers a great deal of information and online programs which help you to be constantly on track with your work, in the event of problems or if you simply desire improvement. One of these online services, that provide you assistance and help, is the Online Backup Services.
Online Server Backup is using software that automates the uploading of selected files to a remote computer and it has the ability to restore files, using internet. Many providers offer a free trial period so that you can determine whether you buy it or not. The online service provider supplies you with software that has to be installed on the Pc or server you wish to backup. The software allows you to select the files to backup and set up a backup schedule. Afterwards, your data will be normally encrypted to secure it from eventual trespassers, compressed to speed up transfer and reduce the amount of storage space required, and uploaded to the server at the service provider's data center. In case you wish to use online backup service, you have to know that the first time you will use online backup, it will take a long time. Of course, there is no exact time, because this depends on the amount of data you want to backup. Generally it is a matter of several hours, but it may also be a matter of days, before the software finishes backing up your selected data, because it has to not only storage your data, but also encrypt, compress and copy it onto the remote server. Data problem has become a critical component in an organization's disaster recovery and business continuity plans. Data is not only the foundation of business but remains a vital irreplaceable strategic asset. Faced with increasingly failed strategies of recovering lost data, disaster planning professional have no other alternative but look for new recovery solutions. _________________________________________ Cheap SEO |
Had same symptoms it was the rear end mounting bushing gone bad
