Fuel gauge not working
Good morning .....this problem occured long ago with the fuel gauge not working on my 02 v70 XC.afterwards my dash cluster went out and I just got around to fixing it.now that everything else is working, I can confidently say the cluster has nothing to do with the issue of the fuel gauge.I am experiencing a dead gauge almost always.in the beginning it did a few different things- such as the needle only going to the red zone ( with low fuel warning light) this would occur in position 2 of ignition switch and after startup, also while driving from dead to same reading mentioned( in red w light illuminated) .One thing to mention is upon firing up new dash cluster, it briefly exhibited same behaviour briefly ( needle from dead to red w light) then right back to showing no fuel.i will say originally all at once the gas gauge rear door locks the tailgate lock and gas door lock control all went out! I have read it may be the rear module .if it is I eventually can send the module out but I am looking to test my way to this affirmation.in addition I am looking to get the gauge working independently if possible! Thanks in advance.any ideas are welcome as long as it's safe!
Rawbertd
03-14-2013 02:51 PM
