Error code 1633 1618 0722 no speedometer
Old Jan 19, 2011 | 09:49 PM
nelsonent1's Avatar
Default Error code 1633 1618 0722 no speedometer
Feb 01 Fixed ... did it myself... The link is below for the abs control fix. A bit of a pain to open up, took about 30 min to pull the box and open it up. Sure enough the board had a broken solder contact on one of the pins in the circuit board. Just added some solder... heated and added solder to all the pins going to the multi-plug... and sealed the box with silicone... installed it and bingo... I am a happy camper. All in all the fix took about 2 hours with 1.5 hours letting the sealant cure. This abs glitch is reallllly common from what all the tech's and threads talk about. I am hear to confirm this problem. I used a pen microscope from Harbor Freight to see the solder problem. Upon the really magnified view, I could see the improper "cold solder" joint that meant the manufacturer didn't heat the thick pins enough. Really easy to fix though. The rest of the circuit board soldering work looked good. It is just that the thicker pins need a lot more heat and time heated to be effective, otherwise this error occurs. Good luck all! Russ
Jan 31 I cleaned the connector to the abs unit and had no problem for 4 days and now the problem is back again... I am wondering if it is my abs unit or the controls for it... the traction light is now coming on in addition to the other lights... then clears up a few minutes later???
I think this explains these problems well http://www.matthewsvolvosite.com/for...?p=46827#46827
Jan 27 Error codes 1633, 1618, 0722, no speedometer (-----), no tripometer (-----), abs light, check engine light, brake light, and sometimes a flashing upshift that occasionally results in reduced power mode on the transmission.... and then it all goes away and runs fine for day/hours/minutes? I reset the codes and all is well for a while. The one code that appears alone... at first... is the 1633. While driving the speedometer just drops out resulting in the above symptoms. Then, magically it all starts working fine again. This behavior was once every two to three months, now daily. I replace the transmission speed sensor yet didn't change a thing. Occasionally, where the dash displays the outside temp etc, I read the word "d i s c"... is there a hard drive in this car? Thanks for the help!
Last edited by nelsonent1; Feb 1, 2011 at 11:38 PM. Reason: fixed abs control additional info and solution
Mark144
2001-2013 model year XC70
Sep 7, 2014 09:01 AM
jocoman
Jun 11, 2014 05:27 PM
spunkymonky
Aug 12, 2008 10:13 PM
khesser
Jul 2, 2007 11:37 AM
DavidSchneider
Jul 7, 2005 12:17 AM
