Front Drive shaft SNAPPED in DIFF!!!Help :(
Old Aug 4, 2009 | 02:34 PM
mtnmotion's Avatar
Default Front Drive shaft SNAPPED in DIFF!!!Help :(
Ok so I am a Dumb idiot.
I was trying to remove the drivers side front drive shaft and while prying it off (with an Air chisel, What was I thinking) I sheared the shaft in the Diff!!!!
Any words of wisdom would be great. You don't have to scorn me, I already feel like throwing up.
Thanks for the input.
2001 xc70
Old Aug 4, 2009 | 07:53 PM
Remove the passenger side axle then the angle gear. Then you should be able to tightly work through the hole from the passenger side and get the piece out of the drivers side.
Old Aug 4, 2009 | 11:39 PM
matt14's Avatar
2001 xc70
What works for next time you need to pull the axles, use a ball joint seperator between the axle and trans. Never had any problems. Just follow techs advice and you should be able to get it out.
Old Aug 8, 2009 | 07:56 PM
mtnmotion's Avatar
Update:
Drilled it, tapped it, pulled it.
Thanks to all for the advice.
What a Dumb A##.
Agian Thanks
Old Aug 8, 2009 | 08:22 PM
Glad you got it out.
s60propshaft
Jan 15, 2023 06:59 PM
MoneypitC70
2001-2013 model year XC70
Oct 26, 2014 08:37 PM
918s60
Jul 25, 2012 11:02 AM
Volvo-Profess
Jan 14, 2011 05:55 PM
rolling2
Sep 25, 2010 12:59 AM
