Front Drive shaft SNAPPED in DIFF!!!Help :(
Ok so I am a Dumb idiot.
I was trying to remove the drivers side front drive shaft and while prying it off (with an Air chisel, What was I thinking) I sheared the shaft in the Diff!!!! Any words of wisdom would be great. You don't have to scorn me, I already feel like throwing up. Thanks for the input. 2001 xc70 |
Remove the passenger side axle then the angle gear. Then you should be able to tightly work through the hole from the passenger side and get the piece out of the drivers side.
Originally Posted by mtnmotion
(Post 174407)
Update:
Drilled it, tapped it, pulled it. Thanks to all for the advice. What a Dumb A##. Agian Thanks |
Glad you got it out.
| All times are GMT -5. The time now is 05:39 AM. |
